JL 500/1 with 3 Diamond Audio subs
Old Jan 21, 2007 | 11:16 PM
s2k_g35's Avatar
What do you guys think of this setup.
2 Front Door DIAMOND AUDIO S600a 6.5" COMPONENT SET
2 rear deck DIAMOND AUDIO D392i 6x9 or precision power PPi dcx 690c 6x9 speakers.
Front, mid and rear are running with the bose amp. The factory 6x9 will be removed and the new 6x9 will be connected to the mid speaker wires.
The rear speaker wires will be disconected.
Subs- 3 DIAMOND AUDIO D3 D308d2 (due to the small trunk space on the G35C)
Amp- JL 500/1 to run the 3 DIAMOND AUDIO D3 D308d2
Punch Cap for the JL 500/1
Old Jan 22, 2007 | 02:16 AM
ltrrtl218's Avatar
i dont know what the wattage ratting on those subs are. but a 500/1 doesnt seem like nearly enough to run 3 subs. u dont need a cap for that amp
Old Jan 22, 2007 | 10:49 AM
Pearl05G's Avatar
Unless youve already heard and liked them, you may be a bit dissapointed in the aluminum tweets from the HEX set. Also may want to consider using 6.5s rather than 6X9s for the rear, if you Must have rears.
Otherwise looks pretty decent for a startup..
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
the93owner
Sep 28, 2015 10:37 PM
