Need help ASAP
Old Apr 5, 2007 | 05:44 PM
8e1point8's Avatar
Need help ASAP
Doing the PAC Audio AAI install in a friends 05X. I was planning on following the directions from http://g35ipod.com/installHW.php?skin=1 but I noticed his 05 is slightly revised with the clock and dash area. Is the HVAC removal basically the same? How do I get to the top bracket. Does the clock still need removed? Any help asap is greatly appreciated.
Old Apr 5, 2007 | 06:49 PM
ttrank's Avatar
Grocery getter
It is about the same. The clock pc comes off in two parts.
Old Apr 5, 2007 | 08:18 PM
8e1point8's Avatar
Help! I was able to get out the HVAC. I pulled out the power harness and sat harness. Hooked up my PAC and had no power. So i unhooked the PAC (auz adapter) and just ran it back stock. Sat harness and Power harness. Now the radio has no power and a/c has no power. What did I DO?! Everything looks connected, i was very gentle with harness' and wires. I dont think i pulled anyhting out. There is one brown harness+wire coming from the gear shift, I dont remember this being plugged in. Any help??
Old Apr 5, 2007 | 08:38 PM
Nickk6's Avatar
Blown fuse?
Old Apr 5, 2007 | 10:16 PM
ttrank's Avatar
Grocery getter
Check the fuse first.
Old Apr 5, 2007 | 11:47 PM
4 Door Skyline's Avatar
+2 check the fuse, then recheck your connections (its foolproof)....and I really hope the key wasn't turned when u began the disassembly.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
