Project Alyssa Audio Portion Complete :) crappy Pics inside
Old Apr 6, 2007 | 07:27 PM
  #31
16psibrick's Avatar
its on the pennisula
b
Old Apr 6, 2007 | 08:34 PM
  #32
nitrouz's Avatar
Thanks Bing.
Old Apr 7, 2007 | 01:02 AM
  #33
nitrouz's Avatar
Thanks for the compliments on the car guys. Yes I'm the owner.
Originally Posted by b00stedjustin
looks nice. You will definitely need those turbo's with all that extra dead weight in your car now.
With 850+rwhp / 820+rwtq, I don't really care much about dead weight...
Old Apr 9, 2007 | 12:17 AM
  #34
Glycerine's Avatar
Nice work!
However i'm a little confused by your pics on the kick fab. Did you use the oem kicks as the base and build up or did you start from a fiberglass mold of them you took?
Old Apr 9, 2007 | 01:55 AM
  #35
nitrouz's Avatar
Originally Posted by Glycerine
Nice work!
he used the oem kicks as the base.
Old Apr 9, 2007 | 02:15 AM
  #36
erdog's Avatar
Hey Bing,
I noticed by the way you have your fans set up (assuming you wired the fans up normally and not reversed), you have 2 fans in push and 4 fans in pull. Wouldn't it be more efficient to do 3 push and 3 pull (not that you think heat would be a big issue anyways since u have never had overheating problems with DLS amps?
Old Apr 9, 2007 | 02:33 AM
  #37
GTR_Boy's Avatar
Hey Alex, I can't wait to hear your system!
Dave
Old Apr 9, 2007 | 10:57 AM
  #38
16psibrick's Avatar
Originally Posted by erdog
Hey Bing,
you pretty much hit it on the head, the fans arent really for the amp lol...they are for the vinyl decal ont he bottom of the plexi, and four fans blowing in covers the widths of the vinyl...
but again, there is no exact science inthis...we arent f1 engineers afterall testing aero in a windtunnel hehe
as lojng as the amp and the sticker doenst overheat, its all good
b
Old Apr 9, 2007 | 11:14 AM
  #39
akachi's Avatar
holy dayam! that z is one of the hottest i've seen
Old Apr 10, 2007 | 01:19 AM
  #40
gramdacious's Avatar
Hey B,
where do you get your fans anyways, I need a few. Is it local? What do you do, just tap them into an amp's 12V+?
Old Apr 10, 2007 | 01:25 AM
  #41
grayvy's Avatar
hottest z i've ever seen. the sq of that system must be nice.
Old Apr 10, 2007 | 03:10 AM
  #42
erdog's Avatar
Originally Posted by gramdacious
Hey B,
I had 2 fans in my old box that i had hooked up in a push pull setup. They were hooked up to a relay switch that was connected to the remote wire coming from the head unit i think. I still have the 2 fans and relay if you want them.
Old Apr 10, 2007 | 10:31 AM
  #43
16psibrick's Avatar
i get them through my supplier to most of my car audio stuff...mine happens not to be local, but you can definetlt get it locally as well...
yup, pretty much what erdog says, remote wire as a trigger for a relay which turns on all the fans
b
Old Apr 10, 2007 | 02:20 PM
  #44
erdog-
Thanks for the offer. Maybe we can work something out, if not no worries. I can get a few at a time on ebay also. So they all have a Black/ground wire, a 12v+/wire, and a third wire/relay that is hooked up to the amp's remote? Sounds easy enough. If I get 12V fans with wire harnesses on them, I can simply snip the harness off and use the 3 wires correct? Thanks for the help guys.
B-
Keep giving us install pics, we love your work.
Old Apr 10, 2007 | 02:41 PM
  #45
erdog's Avatar
erdog-
B-
You can have mine for a whopping 500 pennies.
