Help! no sound after doudle din install!!
Old Apr 29, 2007 | 06:33 PM
vietster's Avatar
okay i just finished installing a alpine HU and 4 channel amp. everything works fine except i get no sound coming out. i double checked all the wires but i can't figure it out. i used a bestbuy wiring harness if that helps. i searched and some said to connect the power antenna with the ground amp and ground wire, tried that but no luck. Any ideas?? thanks
Old Apr 29, 2007 | 06:47 PM
jjyellow's Avatar
Are you running all the speakers through the amp/ any running through the HU. If all running through the amp recheck the RCA cables
Old Apr 29, 2007 | 07:16 PM
vietster's Avatar
yeah im hooking up all the wires through the amp, i did check my RCA wires and still no luck! sigh..i hate it when your so close to finishing but run into a problem.
Old Apr 29, 2007 | 07:31 PM
Callaway's Avatar
can you post some pics up once you get this fixed?
Old Apr 29, 2007 | 07:44 PM
vietster's Avatar
yeah i post pics once i get eveything figured out. its just a regular double-din install, so nothing fancy
Old Apr 29, 2007 | 07:57 PM
g35rcr's Avatar
how did you connect into the factory wiring to run to your amp??? sounds like your harness is not working...you can always just tap the signal by the stock bose amp
Old Apr 29, 2007 | 08:04 PM
Deftronix's Avatar
Does the amp have a power status light on it? is it on?
Also what preamps are you plugging that amp into the back of your deck?
Make sure your deck preamps are enabled in your deck options..?
Did you run wires to all the speakers from the new amp or did you tap the ones going to the bose amp?
Just trying to get a better understanding of whats going on. It will be a lot easier to help you once these things are clarified.
Old Apr 29, 2007 | 09:15 PM
vietster's Avatar
sorry for the confusion guys, i'll try to clear it up alittle. okay for the wiring harness i connected everything but the power antenna, and illumination. grounded the amp turn on and the ground wire together. i channeled the power, remote turn on, and RCA wires all to the trunk. the ground wire for the amp i just screwed to the chassis(sanded off the paint first). Now for the for bose speaker wires i just tapped the bose wiring harness.
got the bose wiring info from this thread: https://g35driver.com/forums/showthr...ght=bose+wires
hope this clears things up for you guys. again, i thank everyone for your inputs.
Old Apr 30, 2007 | 03:27 PM
Gilley's Avatar
Is your amp turned on? Grounding the turn on lead may be your problem. The turn on needs +12 volts.
Old Apr 30, 2007 | 05:34 PM
vietster's Avatar
actually my amp doesnt turn on, i thought it was the amp but i got it tested and it works. not to sure why its not turning on. Gilley, are you talking about the remote turn on wire? not to sure about the 12v thing. can you elaborate on it? thanks
Old Apr 30, 2007 | 05:38 PM
Gilley's Avatar
To turn on, your amp needs constant +12 volts from the battery, a ground, and +12 volts to the turn on lead, which turns on the amp.
If, as you posted, you connected the amp turn on to ground, then no +12 volts is going to the amp. You can connect the turn on lead to the power antenna lead.
Old Apr 30, 2007 | 05:49 PM
vietster's Avatar
i think i know what your trying to say. so i should connect the amp turn on wire(black/white) and power antenna(blue) together and ground it to get the 12v, or connect the power antenna(blue) and remote turn on(blue/white) together to get that 12v?
Old Apr 30, 2007 | 08:38 PM
Gilley's Avatar
There is no grounding involved in the turn on wire. + and - don't mix. I don't know what colr your wires are.
Old Apr 30, 2007 | 09:45 PM
vietster's Avatar
gotcha, thanks alot!!
Old May 1, 2007 | 02:42 PM
vietster's Avatar
update: i didnt ground the turn on wire it was the amp ground wire that i grounded..stupid me. anyways the problem is im not getting the +12v to the remote turn on wire. i tried to connect the power antenna with the remote turn on wire but still no 12v goin through it. any ideas why???
