Quick audio question
i have an 06 coupe with factory BOSE speakers.
is it true that i have to rewire everything if i'm going to install front speakers and a head unit?
and that i can't just get front speakers only, i have to get rear speakers too?
i already have a sub and an amp installed.
TIA
TIA
You don't have to rewire everything. You can tap into the OEM wire harness at the Bose amp. But a lot depends on whether you are adding a new amp or are just replacing the HU and plan to run it through the Bose amp.
What do you intend to do?
marsman328
Northern California
Aug 11, 2015 07:29 PM
