2003.5 in toronto and remote settings
Old Oct 2, 2002 | 05:18 PM
sljer's Avatar
I went to Alta Infiniti today, trying to ask them about the remote setting (more on that later)
My sales told me they just got 14 new shipments today, i think they are mixed with other models because i dont' see 14 new Gs on the lot. Most of the Gs on the lot are in silver and DP colors. Good news is that we have the same changes as the US 2003.5 models. Bad news is we don't have Satelite stereos as option.
As for the remote settings, i showed them the list i printed off from this board. But my sales has no idea you can change it. So, we went to the parts department asking the manager if it's possible. The manager responed by saying "those G35 internet fourm, always finds out information that we dont' even know." He then said it's possible to change the setting. however, we have to charge you $75 to reprogram the computer and the keys!
so now i am still thinking if it's worth it to fork out 75 bucks to program the setting.
YNVMY35
Old Oct 2, 2002 | 08:16 PM
Rumble's Avatar
Re: 2003.5 in toronto and remote settings
What do you want to re-program?
Old Oct 2, 2002 | 08:17 PM
Vancouver_G35's Avatar
What remote settings are you referring to? You mean the settings for the alarm arm/disarm? Its in your manual.
Old Oct 2, 2002 | 09:04 PM
sljer's Avatar
i found this on the freshalloy, so i printed it out and went to ask them
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
YNVMY35
Old Oct 2, 2002 | 10:31 PM
martinss's Avatar
I'm skeptical that reprogramming the keys is required. On my Jetta (which also had remote door locks) I wanted a setting changed - the mechanic plugged in a simple box to an electrical connector under the dash, scrolled through a list of numeric options on a simple diode display and selected the setting I wanted - took about 2 minutes and was free.
I think the comment was made in ignorance - I'm an Alta customer too...
Old Oct 2, 2002 | 10:46 PM
Rumble's Avatar
Re-programming stuff like this was done through fuses on my dad's Oldsmobile Silhouette (van). All GM cars are the same that way.
However, I was given a free key and when they gave it to me it wasn't programmed to even start the car. We found out the next day when after driving the car home. I have to get them re-programmed anyway, and if they charge me ANYTHING, i'll go nuts on them!! =)
Old Oct 3, 2002 | 12:32 AM
sljer's Avatar
I don't think they'll charge you for that, it isn't your fault.
But i am kinda pissed about the whole situation. I am spending 50k to buy a car. They won't even reprogram this little key fob for free? That says alot about the dealership... Hmmmmm....
YNVMY35
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
