Question: Installed my DDK and now Airbag light as come on.
Old Jun 16, 2007 | 11:25 AM
g35man04's Avatar
CLUB MODERATOR
Hey everyone like the title says.....I installed my double din head-unit, amp, and sub about 4 days ago. The problem i have is after the install late on Thursday night when i went to get it my airbag light has come on and is flashing....i cannot get it to go off. The light was never on until late that night on thursday and al day yesterday and today.....My question is if i do an EDU reset or something like that will it fix my problem? Or does anyone know what could of caused this issue?
Please help!!!
Old Jun 16, 2007 | 12:38 PM
bambam26's Avatar
Did you unplug a yellow connector when you were in there if so that was a cable to your airbag you have to go to the dealer to get it reset.
Old Jun 16, 2007 | 01:01 PM
g35man04's Avatar
CLUB MODERATOR
to be honest with you i cant remember...so when i go to the dealer will they just plug up to the computer and reprogram it.
Old Jun 16, 2007 | 03:27 PM
bambam26's Avatar
Yep, they might charge you of course. Just a rule of thumb no matter what car you work on don't disconnect the yellow connectors.
Old Jun 16, 2007 | 03:43 PM
g35man04's Avatar
CLUB MODERATOR
so if my installer just disconnected them for a sec to move some wires and then reconnected them...that can cause it to come on?
Old Jun 18, 2007 | 07:08 AM
driftGT350's Avatar
do a ecu reset, a friend did mine and it went away. good luck.
Old Jun 18, 2007 | 08:39 AM
g35man04's Avatar
CLUB MODERATOR
ok thanks. i have these steps to do that so i wil try it again.
Old Jun 18, 2007 | 10:03 AM
SFLG35's Avatar
FGC President
there is a specific way to reset the airbag light. its posted somewhere on here, but i dont remember where.
Old Jun 18, 2007 | 10:45 AM
bassholic's Avatar
Mine is flashing too after i installed my nav unit! I figured i'd just let it keep blinking until i decided to go to the dealer. I figured i'd knocked some plug out some how. Let me know if this works for you i guess i'll try tonight if i find instructions on here
Old Jun 18, 2007 | 11:06 AM
bassholic's Avatar
Time to say i just went out to my car and after a few tries of off on i finally got it down and the blinking went away. Guess i should have looked this up a month ago. I really thought i might have damaged something.
Anyhow where i went wrong was turning from ACC to LOCK. It is ACC to OFF or click 2 to click 1 and viola the damn blinking light goes away.
Of course another thanks to G35!!
Old Jun 19, 2007 | 09:28 PM
g35man04's Avatar
CLUB MODERATOR
Allright everyone. I found this on the web and did it the first time and everything worked perfect! Someone should sticky this!!!
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Ignition Key Method:
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
Old Jun 22, 2007 | 02:23 AM
shipsaeki's Avatar
did you check the connected behind the glove box for the pass side air bag? most likely that is the culprit.
Old Jun 22, 2007 | 09:33 AM
g35man04's Avatar
CLUB MODERATOR
yeah i did. I didnt ever unplug that.
Old Sep 24, 2007 | 10:04 AM
g35man04's Avatar
CLUB MODERATOR
hey everyone i am still having this issue...i reset and a day later it will come back on...sometimes it stays off for 2-3 days and then when I get a passenger it will come back on again...not sure why....I have checked all the plugs and everything is connected.
Old Sep 24, 2007 | 10:32 AM
Gilley's Avatar
Since it does it when a passenger gets in, maybe it's a legitimate warning. I had my passenger side seatbelt harness tensioner replaced after the airbag light came on. It may not be due to the audio install.
