Audio Help
Old Aug 13, 2007 | 01:48 PM
SteveBlake's Avatar
Question Audio Help
I bought new speakers for my coupe but do I HAVE to have component speakers for the front? and will Polk DB650's work in the rear panels? I was also planning on installing them myself, is there somewhere that has step-by-step instructions or can anyone give me some?
Old Aug 13, 2007 | 07:40 PM
digitalhifinet's Avatar
No, you don't have to have component speakers, but you will get better imaging if you do, just because the stock woofer location is bad for imaging higher frequencies. As for a tutorial I have not seen specifically for door speaker installs, but do a search for door panel removal, and the rest is pretty self explanitory. Both myself and milox have threads with pics that show the door panels off, so you may be able to gather something from that if nothing else. And just as with the fronts, the backs will require a baffle to mount, because of the retarded bose 3 screw mount system (Let's be cool and use 3 screws instead of 4 like everyone else).
Good luck
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
