Need Help Identify Wires Plz..
Old Sep 4, 2007 | 03:37 AM
JTG35's Avatar
Can someone please help me to identify if these connections are correct. Do I have to connect the Z1's Auto Antenna wire to the Power Antenna wire from Scosche NN03 harness? Since we don't have Auto Ant in our car right?
I can't find where to connect these two wires as well. One is Amp Turn-on (12V+) wire and the other is Amplifier Gound. Are these wires on factory harness in the front (if it is what colors are they?) or I have to run it from the Amp's wire in the trunk. Please help. Thank you.
Old Sep 4, 2007 | 04:44 AM
Meatshackle's Avatar
Deep Sea Moderator
Looks like an octopus screwing a bagpipe.
Old Sep 4, 2007 | 09:34 AM
Gilley's Avatar
In a sense, we do have a power antenna. There is supposedly a power module for the antenna that does need to be connected. There are both an amp turn on wire and a power antenna wire on the OEM harness, but I don't know which wires they are. I know I have connected them then installing a new radio and using the Crutchfield wire harniess adapter.
Old Sep 4, 2007 | 01:04 PM
JTG35's Avatar
Ok so the blue (power antenna) will need be connected.
I am using scosche NN03 wire harness that fits the oem harness. After the LOC is installed, there were 2 amp wires left. Since these 2 wires directly coming out from oem harness, I assume they are suppose to be connected with the Z1 hu. Wait a minute.........Z1 hu has 3 connectors. RCA cable connector #2 has a power amp wire there, could that be it? If it is then how do I connect the amp ground? Can I ground it like I ground all the black wire?
Old Sep 4, 2007 | 02:45 PM
Gilley's Avatar
The ground can be grounded with the other ground wires.
Old Sep 4, 2007 | 05:44 PM
JTG35's Avatar
Thanks Sean
Old Sep 5, 2007 | 04:17 AM
Deep Sea Moderator
My turn-on was sky blue.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
