12V Source in Engine Bay
Can anyone tell me where I can find a 12V (that is live when the engine comes on in RUN, not START) in the engine Bay area?
I need to tap into something (Fuel pump relay, oil pressure relay, etc..) that is live when the engine is running...I have the manual but haven't been able to locate anything on my own...I have an 06 Coupe, auto if that helps.
Thx
Thx
Originally Posted by filanj
No need for 3 threads in the same section. Please delete 2 of them.
I think the moderator already did...sorry...computer was frozen and sent a duplicate when I hit enter again
You could always run a wire from under the dash to the engine compartment. If you don't want to do that you may find switched 12vdc in the brake compartment, for the ABS system (make sure you fuse it if you go this route).
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
