Polk EX3500 Install?
Old Feb 12, 2004 | 12:20 AM
Gotchaa's Avatar
I just got these 1" tweeters, and looked through some posts noticing that most people have the Polk crossover with the unit. Since I just bought the tweeters, I don't have the Polk Crossover, does that mean I need to install or bypass a capacitator in order to get the right crossover frequency to the tweeter or is the crossover built into the tweeter itself on the Polk and Bose and all I need to do is swap them out? Any advice or links to DIY's would be much appreciated. Thanks!
Old Feb 12, 2004 | 10:38 AM
Micah's Avatar
Re: Polk EX3500 Install?
If there isn't a capacitor embedded in the tweeters' wire leads, then you will need to add one. The tweeters will melt in a hurry if you run them full range.
Old Feb 12, 2004 | 10:12 PM
Carlos3186's Avatar
no there already is a cross over on them. its that circet bord thing on the wires. its been a long time scince i did mine but i deffently remember there being a cross over. its just not a big as the one the guy did in that pictoreal. It will sound great when its done. Do you have a coupe or a sadan? if u have a coupe u will need to cut the cornors of the tweeters inorder for them to fit in the stock mounting location. Or at least i had to do that. if u need help with it on a coupe drop me a PM and i will help you out.
Good luck, and they are well woth the time to install
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Feb 13, 2004 | 08:56 PM
Gotchaa's Avatar
I've got a Sedan. But If it's on the wire for the Bose, I guess I just need to know where to splice in so I make sure I get the Bose crossover out. Any ideas?
Old Feb 14, 2004 | 01:31 AM
G35MD's Avatar
I upgraded my tweeters with Infinity 1" and used a 10uF capacitor as the crossover as described in other threads. I got the capacitors for $0.99 each at Radio Shack.
I think the sedan is a little different than the coupe including the color of the wires going to the tweeters, but I don't know for sure.
Dr. Jim
2003 DesertPlatinum/Graphite G35C 6MT
Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG/NismoChromeShifter/RacePedals/Z-tube/JWTPopCharger
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
