Parking lights NOT working please help me find the problem...
Old Oct 11, 2007 | 05:00 PM
dream_G35's Avatar
I just got my car back from the shop yesterday!! (pics to come soon ) and everything is perfect except for the fact that my parking lights are not working.
The main problem is my tailights, the headlights turn on fine but my tails are completely off unless i hit the brake pedal which in turn they light up. Other problem that might be related...My clock/centerconsole lights and dimmer switch are also not functional.
I checked all the fuses (driver kickpanel and next to battery) and they are fine, i checked the connection at the tailight and it is also fine. Is there anything i can use to see if there is a shortage somewhere or through what other means can i find this problem?
A friend told me to check my relay, but i have no clue where or what it is and what to replace.
TIA for the help
Old Oct 11, 2007 | 05:28 PM
Glycerine's Avatar
So no parking lights, no lights on tail lights, no console lights. Sounds like they left something unplugged :/ I'd take it back tomorrow (call them today if there's time) and make them fix it.
Old Oct 11, 2007 | 09:50 PM
dream_G35's Avatar
found the fix. it was a secret fuse box.
Old Oct 12, 2007 | 12:53 AM
shipsaeki's Avatar
lol... secret fuse box? Are you refferring to the IPDM
Old Oct 12, 2007 | 02:46 AM
dream_G35's Avatar
Uhh I dunno what IPDM is but its a vertical box on the firewall under battery, have to take off passenger cowl to get to it.
Old Nov 24, 2008 | 12:28 AM
paky786's Avatar
so I have to remove the battery to find this?
Old Nov 24, 2008 | 12:45 AM
Sponger's Avatar
6MT Brembo Coupe
What kind of work did you have done? Are you getting a voltage reading at the sockets?
Old Nov 24, 2008 | 01:58 AM
gizmo134's Avatar
the infamous 3rd fusebox! someone should sticky something explaining that they put the 3rd one in the most impossible retarted position imaginable.
and if a fuse blows, theres a 90% chance its in there.
Old Nov 24, 2008 | 01:16 PM
paky786's Avatar
See, I had the SAME EXACT problem that dream G35 has.. My taillights would not work unless I press the brake and my interior dash is not lit. I had no idea that it was messed up while I was driving til my friend that was following me told me lols and ever since I was afraid a cop will pull me over! Anyways, I think I know where the 3rd fusebox is, but do I have to take the battery out?
Old Nov 24, 2008 | 02:16 PM
gizmo134's Avatar
if you take off the plastic that runs accross the bottom of the windshield you shold be able to get to it
Old Nov 24, 2008 | 02:21 PM
paky786's Avatar
thanks, I figured it out like an hour ago and it was the same exact problem! My 10A fuse was out for the taillight, now my interior and taillights work! Yay to this thread, I LOVE THIS FORUMS!
Old Dec 2, 2008 | 10:41 AM
Smokey6's Avatar
I'm having the same problem - my console lights and parking taillights don't work.
I only know of 2 fuse boxes in my '04 G35 sedan...one next to clutch pedal in the lower dashboard, and one just in front of the battery after taking the passenger battery cover completely off. All of the fuses in these locations tested out OK with my fuse tester.
Can someone please tell me exactly which fuse when blown causes this problem?
If it isn't a fuse, could it be a relay?
Old Dec 2, 2008 | 11:08 AM
MidnightG35X's Avatar
This really needs to be a sticky... I've responded to two posts already today about this, and I know there was at least one more. Check the post below...
https://g35driver.com/forums/audio-v...de-marker.html
Old Dec 2, 2008 | 01:14 PM
Smokey6's Avatar
I actually ended up finding the thread you listed via copious searching prior to you posting it (but thanks!). Now the problem for me is that the taillight fuse just keeps blowing when replaced with fuse of same amperage (10A). Any suggestions on where/how to look for the short?
Thanks in advance.
Old Dec 2, 2008 | 02:39 PM
paky786's Avatar
Could it be your radio? It's the reason mine fused out
