VSS Wire
Old Nov 2, 2007 | 11:48 AM
blownvert's Avatar
VSS Wire
Where is it on my 04 g35x? I took the center console out and tried to find the wire from my z1. Its the pink wire from z1 on my power cable harness and i tapped into it on a harness that was the top right one that looked white with green stripe. It still didnt do my speed pusle in the unit. Im asking where is the harness from my g35x? I cant find it i guess, there is so many harnesses. Please i dont want to go back and pay the person that was awhile ago. He never conntected it, it seems like. The pink wire was cut short.
Old Nov 2, 2007 | 06:06 PM
blownvert's Avatar
it is not the light white/green wire next to the red wire, blue stripe on the 10x2 harness. that wire does not work when i tap it for speed pulse. where is the wire!
Old Nov 2, 2007 | 06:13 PM
(>")> G35's Avatar
*EDIT*
This thread may help...
https://g35driver.com/forums/questionable-posts/173964-diy-using-navi-while-driving.html
Old Nov 2, 2007 | 06:59 PM
blownvert's Avatar
this does not help, am i looking for a harness that is just hanging there thats not in use? I tapped a light white/green wire blend and it didnt work. Is the harness only have 4 wires on it because i think this one has 8 or 10. Also mine didnt come with stock navi.
Old Nov 2, 2007 | 07:10 PM
KPierson's Avatar
You should be able to find it up at the A/C display board. It should be a white/green wire. Grab a volt meter that reads frequency and test any white/green wire you find there.
I wouldn't advise just hooking things up to try them.
If that fails, grab a service manual for your year/make/model and start looking for the signal at various places. I actually thought it was already at the radio, since the G35 (at least my coupe) has speed sensitive volume control.
Old Nov 2, 2007 | 07:12 PM
(>")> G35's Avatar
DEI says it's a white/green wire on a 2 pin radio harness. try to find that.
On a 350z it's a white/grey wire. Is there one on the radio? if so try that...
Old Nov 2, 2007 | 09:41 PM
blownvert's Avatar
what is a 2 pin radio harness? I am not good with harnesses, how do i know which one is which, is it the harness that is not connected? I saw 1 harness that was not connected that was apart of the big cable connection that had 3 coming out of it i think. the main car harness.
Old Nov 2, 2007 | 09:42 PM
blownvert's Avatar
When i remove the z1 and the whole dash part, all i see is harnesses down below behind it. I dont see anything up above where the pocket is.
Old Nov 2, 2007 | 10:46 PM
blownvert's Avatar
help please
Old Nov 3, 2007 | 10:22 AM
blownvert's Avatar
bump, i dont have stock navi so the harness would not be under the glove box either. am i just looking for a harness that is only 4 wires, i know 1 harness is not connected maybe that is it.
Old Nov 3, 2007 | 11:05 AM
ttrank's Avatar
Grocery getter
I didn't have a navi. Mine was at the oem stereo and white with light green.
Old Nov 3, 2007 | 11:08 AM
blownvert's Avatar
is it on a harness that is not connected? I have one connector not connected just hanging there. I tapped a wire that was a blend of white and green light color, upper right corner it had no stripe in it. It was next to a red wire with blue stripe. that was not the one. i want to open it back up tommorow and try again. where is the wire?
Old Nov 3, 2007 | 04:54 PM
mars35's Avatar
having exact same issues... I cannot even locate a white/green wire.... help!!!
last wire to do...speed sensor...and then Im done!!!
anyone out there?????
Old Nov 3, 2007 | 05:36 PM
blownvert's Avatar
mine is connected and everything i just went back to do the speed sensor because shop never connected it. always says 0 in connection status in hardware, never moves up. i will see if i can locate it tomm.
Old Nov 3, 2007 | 10:16 PM
blownvert's Avatar
helpppppp is it the harness that is not connected?
