JDM A/C Controller
Old Nov 14, 2007 | 06:59 PM
08G37TX's Avatar
JDM A/C Controller
I got my JDM Double Din finisher and A/C Controller today from Riverside Infiniti. When I opened up the A/C Controller, the resistor and LED were already on the board and it is only missing the button.
The buttons on the one that I got seem to look different than other pics I have seen on the board.
I am assuming that all I will have to do in order to keep my Dual Climate would be to move the button over and that is it since it looks like the LED and resistor come on the JDM board now, or am I missing something?
Here is a pic of the one that I got.
Old Nov 14, 2007 | 10:16 PM
Gilley's Avatar
From your user name, it appears that you have an 04 G35. If so, you only need to move the button and button cover.
Old Nov 14, 2007 | 10:23 PM
08G37TX's Avatar
I was not aware of that, but it was a nice surprise to only have to move the button and cover.
Old Nov 15, 2007 | 03:15 AM
minus500's Avatar
It looks like your going to have to solder on the small green button that is missing at that particular location or am I missing something?
Old Nov 15, 2007 | 08:13 AM
08G37TX's Avatar
Yes I will, I was thinking I would have to solder the button as well as the LED and resistor.
Old Jan 2, 2008 | 06:33 PM
fherjohn's Avatar
i soldered mine on and it works fine.
Old Jan 2, 2008 | 06:58 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
here are pix from my original DIY guide for the DCC (dual climate control) button swap...
<a href="http://imageshack.us"><img src="http://img181.imageshack.us/img181/5859/dccpb5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
<a href="http://imageshack.us"><img src="http://img337.imageshack.us/img337/7672/dccswapbs2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
<a href="http://imageshack.us"><img src="http://img80.imageshack.us/img80/2269/dccbuttonwg2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
<a href="http://imageshack.us"><img src="http://img337.imageshack.us/img337/9321/newdccyl5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
hope this helps...
doc
Old Jan 2, 2008 | 07:06 PM
2drwild's Avatar
my controller seems not to work right if I set it to 60 degrees I get A/C if it goes 61 or higher I get heat..Any help?
Old Jan 2, 2008 | 08:59 PM
allendoc's Avatar
I know this thread is for pre 05 Double Din conversion, but has anyone figured out where the resistor on the 05+ is on the DUAL SMD? I have the SMD moved over, and the switch, but the light has never worked. There is a old thread that a banned guy, and his pictures are bad now. Anyone? Sean? I can not find the resistor and I have followed the circuit runs.
Old Jan 2, 2008 | 10:31 PM
Gilley's Avatar
Here are pics of the 05-07 AC controller. The circled areas show where you have to solder on a resistor, LED, and the button. According to my friend silvernole, the resistor you pull is marked "242". The circles show where the respective parts need to be moved.
Thanks to silvernole for the pics and for figuring this out. I have an 04, so I didn't have to contend with any of this.
The first pic appears to be the USDM controller and the second pic shows where parts need to be soldered.
Old Mar 16, 2024 | 04:54 PM
Kiefer's Avatar
Sedan 6MT
is anyone still around to answer some question on this? I’m wondering where we need to move R242, LED, & button to. Looks like a couple of photos are missing now and I can’t tell where to move the circled items.
Old Mar 16, 2024 | 05:58 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Nothing's missing.
The first photo shows where on your original board you can get your "donor" resistor, LED and button from. Desolder them from the board.
The second photo shows where you have to put the resistor, LED and button from your old board.
G35Rican
Jul 31, 2024 01:37 AM
JLee301
Sep 25, 2015 08:46 PM
bigmike
Sep 17, 2015 01:58 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
