Anyone running Jl Audio 10w6 with 1000/1
Old Nov 20, 2007 | 10:28 AM
Meth68's Avatar
I can feel the love...
Old Nov 21, 2007 | 08:04 PM
blind_side1's Avatar
Gilley, so I did some research on capacitors, and I now understand there uses.
Did you install your capacitor before or after installing your apline amps? In other words, did you encounter a problem with your amps drawing too much power from your battery and therefore needed the capacitor?
I'm running to "sally" amps right now, and I have not noticed any power draw down. However, I soon plan to go with a set-up similar to yours, and I need to factor it in for budget reasons if it's needed.
Old Nov 21, 2007 | 11:29 PM
Gilley's Avatar
I installed the capacitor at the same time as the amps anticipating that I would need it. I took it out for a little while and found that I do need it. The lights dim to the beat. The amps total 1600 watts rated power.
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
