Reversing Directions in Navigation System
Old Nov 21, 2007 | 08:47 PM
ddronron's Avatar
I have a G37 Sedan with Navigation. One annoying omission seems to be the inability to simply program the unit to reverse directions used to get from point A to B. You can store a tracked route, but that only helps you repeat the original route used from A to B. Does anyone else have an issue with this? When you use MapQuest or GoogleMaps, you can print reverse directions and I am wondering if there is a way to do a similar thing with the Nav system. Thanks for reading and responding.
Old Nov 21, 2007 | 11:33 PM
Gilley's Avatar
Can't you just tell it to get you back to the starting point, like point A from point B?
Old Nov 22, 2007 | 12:42 AM
trueskillz12's Avatar
where did you get a g37 sedan?
Old Nov 22, 2007 | 01:59 AM
2K6G35's Avatar
Yes, that's what I thought too. what is a big deal?
You can always point it back to previous starting point once you reach your destination and vice versa.
Old Nov 22, 2007 | 02:00 AM
2K6G35's Avatar
He's probably referring to 08 G35 sedan
Old Nov 22, 2007 | 05:48 AM
ddronron's Avatar
Reversing directions
I meant I have a G35 sedan, not 37. You can not just tell the nav system to reverse directions, because it will use its default setting, not the actual route you took. What I am saying is you should not have to reprogram a return trip to follow the route you took, but should simply be able to retrace your route.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
joeslates
Sep 11, 2015 11:19 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
