Searched everywhere, remote entry question
Old Jan 17, 2008 | 09:12 PM
scottkusf's Avatar
Hello - Ive searched a lot on the forums and cannot find what im looking for. I know you can turn off the horn chirp, but is there a way to program entry so that the headlights turn on when you unlock, or any other sort of feature? Also, is there a way for the auto headlights to stay on for a minute or so after the car is locked and then turn off later?
Thanks!
Old Jan 17, 2008 | 11:13 PM
Roguewolf's Avatar
not that i know off.. my friend's maxima has that feature where u can set the light duration after u leave and when u come back ect etc. I would love to find out we can too.. find my G winkin at me in the parking lot
Old Jan 18, 2008 | 12:46 AM
John Henry's Avatar
Yes, set the lights to Auto.
Old Jan 18, 2008 | 12:58 AM
Roguewolf's Avatar
no he means when he presses the unlock button from outside not when he turns the key... i think lol
Old Jan 18, 2008 | 06:31 PM
overdrve's Avatar
Technically it is possible. When I was doing an alarm install on my daily commuter, I ran into a timed relay switch. You could theoretically wire the unlock wire to trigger the relay. Then you can feed the outputs of the relay to the headlight switch wire. The relay can be adjusted to various time limits. The timer relay itself ranges from $15-$30 depending on where you get it at. Just be sure you are aware of the amperages you're feeding to which signal. Feeding 12A to a low amp 500mA signal feed would blow out circuits.
Old Jan 18, 2008 | 07:01 PM
dave's Avatar
The BCM can be customized somewhat. See This post in the FAQ section.
YMMV
Old Jan 21, 2008 | 12:37 AM
jibnasty's Avatar
just mess with holding both lock and unlock at the same time. I was trying to get my windows to roll down with the remote (hold the unlock) and the lights and horn stopped going off by mistake. I think its just holding both buttons....
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Texasscout
Jul 24, 2015 03:43 PM
