Microsoft Zune
Microsoft Zune
I just picked up a zune and want to get an Auxillary Port + the charger thing like they make for the ipod which gets rid of the cord that plugs in and plugs into the bottom of it.
Can someone lead me in the direction and tell me what i would need to get? I was looking around but soo many different types im confused :/
Thanks
Thanks
I have only found one retail product:http://imedock.com/zune.htm
It's ridiculously expensive. The only other options are to build your own:https://g35driver.com/forums/showthr...highlight=zune
Or use a PAC-NISII, plug it into the back of your HU but then you only get the standard stereo inputs, not the dock connector.
Options are slim for the Zune. No matter what, you will need an Aux adapter, USA-Spec makes one as well as PAC.
DLO makes a charger/dock w/ outputs but it is pretty much panned by everyone @ amazon
Only other option is to adapt a home dock for use in the car.
Edit: Kicker/Soundgate showed a car audio solution for the Zune, but from surfing the Soundgate site they don't seem to make stuff for Nissan/Infiniti.
http://forums.thoughtsmedia.com/showthread.php?t=32033
