SWI-Jack Set-up
Old Feb 6, 2008 | 11:36 AM
blind_side1's Avatar
SWI-Jack Set-up
Anyone have any pictures of thei SWI-Jack install? Specifically, how do I connect the 150 ohm resistor and 47 ohm resistors to the Infiniti harness?
Also, when you remove the factory bose head unit, you have to unplug four connectors. Of the four connectors, only two are used with my Kenwood head unit. Therefore, which of the four vehicle connectors is the one I use for the SWI-Jack?
Thanks
Old Feb 8, 2008 | 11:09 PM
You two! You!
You two!
Look!
Whippoorwill, whippoorwill!
Look up here, look up here!
Hey, you, look! Up here!
Up here, up here!
Hey, you guys!
This way.
Come on, someone's has to know something about this????
Old Feb 9, 2008 | 11:14 AM
Gilley's Avatar
The instructions are pretty straightforward. There are 4 plugs in the back of the radio. Two are for the power and audio, one is for the satellite radio tuner, and the other is for the steering wheel controls and will have the fewest wires.
You will tap intothe red and green (I think those are the colors offhand) and connect the correct resistors to each of those wires and then connect them together to the white wire on the PAC.
Old Feb 14, 2008 | 10:18 AM
So I got the SWI-Jack installed last night per the instructions using a Kenwood 8019 head unit. However, I can't seem to get all the functions to work. For example, I can get the volume up and down and source buttons to work all the time. I can also get the seek buttons to work while in Radio (Tuner) mode (the seek buttons will change the radio station up or down). But, the seek buttons don't work in CD or iPod mode.
Anyone else see this? Any suggestions is greatly appreciated.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
multimut
Canada
Jul 26, 2015 08:43 PM
GBousis
Dec 15, 2005 01:12 AM
