cheapest/easiest ipod solution?
Old Feb 8, 2008 | 05:15 AM
jesseislil's Avatar
I have an '05 sedan.
What is the cheapest and easiest way to integrate my ipod?
Does the stock head-unit have an auxillary input?
Old Feb 8, 2008 | 07:02 AM
akachi's Avatar
usa spec
Old Feb 8, 2008 | 01:58 PM
jesseislil's Avatar
Originally Posted by mx22o
usa spec
What's that?
Old Feb 11, 2008 | 01:58 AM
Jayou Ayen's Avatar
Originally Posted by jesseislil
What's that?
http://www.usaspec.com/images/full_view.jpg
I just bought one from Crutchfield.
39
Old Feb 11, 2008 | 07:50 PM
Aced16's Avatar
how does that work, i have an 04 coupe....
Old Feb 11, 2008 | 10:24 PM
TeddYang's Avatar
Ohio G Club Member
you can also use the Nissan Factory Ipod Integration kit from www.everythingg35.com w/ instructions for a clean install on the website.
http://www.g35parts.com/9083/osc/pro...roducts_id=521
it's a pretty easy install, i have an '05 Sedan also (works for coupe also), and all you do is plug the unit into a wire that's in your trunk (for sedan it's behind the felt covering the back of the rear seat, for the coupe I THINK it's either on the left or right side of the spare tire, where the bose amp is). Your ipod plugs into the unit and then voila your ipod will now play on your head unit.
if you don't opt for the clean install and don't mind having the ipod in your trunk, it'll take 30 min max
Old Feb 22, 2008 | 01:20 AM
nfo184's Avatar
which one is the plug and play for your trunk??
Old Feb 22, 2008 | 01:27 AM
ShanesG's Avatar
the one ted yang posted, will prob be the easiest for you, the USA spec one, i think you have to take your HU out and wire it to the back of your HU, i got the plug and play one from everythingg35.com, if you search you will find my DIY on how i installed mine in my center consel
Old Feb 22, 2008 | 01:31 AM
mt7rabbit's Avatar
awesome I'm going to look into doing this asap.
Old Feb 22, 2008 | 01:37 AM
nfo184's Avatar
i have the coupe with this in my trunk
Old Feb 22, 2008 | 01:38 AM
nfo184's Avatar
Old Feb 22, 2008 | 01:39 AM
nfo184's Avatar
will anything work with that?
Old Feb 22, 2008 | 01:41 AM
ShanesG's Avatar
yes the white connector to the left is the only thing you have to connect from your car, the kit comes with everything else you need
Old Feb 22, 2008 | 01:42 AM
ShanesG's Avatar
if you looked in the other thread you posted in you would have seen my write up which shows everything
Old Feb 22, 2008 | 02:31 AM
nfo184's Avatar
where can i get the kit and which one ....the USA SPEC PA11 NIS one ??? or this one iPod Factory Integration Coupe/Sedan
[999U7-IPOD]
