Need Help with Wiring ASAP
Old Feb 18, 2008 | 04:27 PM
1trueG's Avatar
Im currently running 4 gauge wire through my G coupe and I need to run it to the trunk now. I read the DIY and it says to lift up on the rear seats and they will come up but it is not working for me. Is there any other advice?
Old Feb 18, 2008 | 04:46 PM
LEE13's Avatar
The rear seats should come up. You might need to give it a little muscle. I think if you get your hand in between the space where the seat meets the carpet you should be able to pull up and feel the seats give.
Old Feb 18, 2008 | 08:48 PM
Gilley's Avatar
Lift up at the front edge of the bottom seat cushion in the middle.
Old Feb 18, 2008 | 10:24 PM
1trueG's Avatar
Got it done...Thanks...
Old Feb 19, 2008 | 10:02 AM
Rocket1991's Avatar
pulling out that rear seat was the biggest pain in my a** during the install. never had such a tough time with any other back seat.
Old Feb 19, 2008 | 12:31 PM
1trueG's Avatar
It was actually pretty easy...Just wasnt sure if I was supposed to pull up so hard or not. Plus I didnt wanna break anything...
Old Jun 5, 2008 | 11:32 PM
monkey2003's Avatar
Wiring Instructions/Pictures
I can't seem to find the DIY post that you guys are talking about. I also need to run the Monster wires from the battery to the trunk. Is there any pictures/instructions on how to do this??? i can't seem to find it. Thanks for the reply..
Old Jun 6, 2008 | 02:53 AM
Meatshackle's Avatar
Deep Sea Moderator
If you remove both plastic pieces covering the battery you'll see where the factory wires go through a large boot near the hood hinge and windshield. You can cut a small hole, just big enough for your wire and feed it through. You have to seal it up with silicone afterward or your ECU will swim the next time it rains.
Old Jun 6, 2008 | 02:59 AM
Deep Sea Moderator
https://g35driver.com/forums/faq-diy/14587-running-wiring-underhood-interior.html
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
