Parrot CK3000 install
Old Apr 2, 2008 | 08:23 AM
Capitol G35's Avatar
I installed my Parrot Bluetooth CK3000 hijacking the passenger side cig lighter for power and ground. I have aftermarket amplifiers so I cut and spliced a pair of RCA cables to run into the speaker inputs on the BT unit itself and used barrel connectors to connect to the output of the unit. I hooked up the mute wire and everything works the way it's supposed to but it sounds terrible and loud. I'm thinking that I need to put in resistors but where would I do that? What rating would I use? Would this be in between the RCA splice and the unit input?
Also, i've got a nasty whine as well when I turn the key to ACC. I assume this is the current coming from the heater fan and it's probably the ground but the ground is OEM so it should be a sturdy ground.
Old Apr 2, 2008 | 01:39 PM
g35rcr's Avatar
sounds like you didnt ground it correctly, just ground another connection on to bare metal
Old Apr 2, 2008 | 02:30 PM
I used the ground from the cig lighter...which all I did was cut, splice, twist wire together, and tape. I'm thinking about running the BT unit going out of the amp. We'll see. Thanks.
Old Apr 5, 2008 | 02:14 PM
Finally isolated the noise but it is incredibly too loud even when I turn the BT unit volume down. Anyone know of a way to keep the volume down or another way to route the input and output?
Old Apr 5, 2008 | 08:35 PM
Nevermind...this BT unit is nice. I ran the input to amp and the output to the speakers. Of course because i'm running three sets of patch cables the sub still plays when everything else mutes. I just have to press mute on the HU to get it to stop but that sort of defeats the purpose. Oh well...at least i'm not having to charge a headset.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
