Alpine PDX...What are they!
Old Apr 5, 2008 | 07:06 PM
GD-Up's Avatar
Hi All,
I need to upgrade my mono amp..its too small (350watts RMS) for 2X 10" DVC subs (400/800w)
so I hear about these alpine PDX sub amps and they push the same power through 2 or 4 ohms. So if it is a 600w amp is that the rms power? is there even rms and peak power with these amps?
Old Apr 5, 2008 | 07:11 PM
simpson's Avatar
there is more power in there they r nice amps i have had a buch of them in all my cars
Old Apr 6, 2008 | 12:58 PM
Puzzle's Avatar
They're a new line of amps,
Basically a full range class D amplifier (Thought I'd never hear those words in the same sentence). They are very efficient, meaning that they don't need to draw as much current as a comparable amplifier, and they run very cool in a small package. Bit on the expensive side right now, but if you've got the funds, they're a good buy. The circuitry is designed (and patented I believe) by Bang&Olufsen, and is already being used in high end home audio applications.
Bottom line, Expensive, but good.
Oh,and you'll start seeing less and less Peak power advertisement as most manufacturers start complying to the CEA standards...
Old Apr 6, 2008 | 10:07 PM
GD-Up's Avatar
Ya they really look nice!
I swaped my V-power for a PDX 4.100 for the components.
Now I am not sure if I need the 1.1000 or 1.600 to run the 2x10"?? (400rms each)
Also my box is 1/2 the volume it should be for these subs...will "inverse mounting" help at all as the sub magnet does not use any volume since it is now outside...any thought on that type of mounting?
Old Apr 6, 2008 | 10:49 PM
Puzzle's Avatar
You would need the 1.1000.
Half the recommended volume is a lot. Of course, your best option is to rebuild the box, but if that's not a possibility, reverse mounting + poly fill should help a bit, but you won't be getting full output from the subs, and you may be disapointed.
When it comes to Subs, cabinets are 75% of the experience
Old Apr 6, 2008 | 11:26 PM
GD-Up's Avatar
Ya, I know...Im trying my best to half *** a fix for buying too small of a box. The shop says I need a fiberglass set up (which is fine), but it's gonna cost like $1200.00 for a box. Thats a bit steep, plus I don't want to lose my whole trunk.
Old Apr 6, 2008 | 11:31 PM
Greatwars's Avatar
Originally Posted by GD-Up
Hi All,
based on the alpine website, it's the rms power:
http://www.alpine-usa.com/US-en/prod...&lang=en&tab=F
ignore the peak power, it's just marketing bull
Old Apr 6, 2008 | 11:32 PM
Greatwars's Avatar
what subs do you have?
Old Apr 6, 2008 | 11:44 PM
GD-Up's Avatar
2x 10" Kicker Comp VR
Alpine Type X components
Alpine Type R 6X9
PDX 4.100
Rockford P 325 for subs...to be upgraded to PDX 1.600 or 1.1000
All in a Zenclosure box....really small.
Old Apr 7, 2008 | 12:16 AM
Greatwars's Avatar
Ya, i would say you go with higher amps, in this case 1.1000 for the subs... it's better to overpowered it than underpowered it.
I dont think that giving 300 rms each to 400 rms subs would clip the subs but I dont see any min. recommended wattage so i wont make any assumption... but if you want to maximize ur subs, you would have to go at least 400 rms each anyway so better go with 1.1000
Old Apr 7, 2008 | 07:58 AM
Gilley's Avatar
For about half that price, you can get two enclosures from www.4080enclosures.com AND still have plenty of room in the trunk.
I have a PDX-1.1000 driving teo 10w6's in 4080 enclosures and it hits pretty good to me.
Old Apr 7, 2008 | 10:33 AM
GD-Up's Avatar
Ya, I was considering that.
Old Apr 7, 2008 | 11:36 AM
tjlazer's Avatar
How you got that wired up? You got the 10w6v2's wired up at 4Ohms?
Old Apr 7, 2008 | 01:02 PM
Gilley's Avatar
I forget how I have them wired. The subs are dual 2 ohm voice coils, so I think I wired each voice coil in series. I know each sub is wired to its own plug on the amp.
Old Apr 8, 2008 | 11:13 AM
blind_side1's Avatar
Gilley, what guage wire are you running from the battery. I too have the PDX 1.1000 pushing two 10W6v2 in 4080 enclosures, and my amp cuts off at high volume with big bass. I'm running 4 gauge from the battery to the amp right now.
