What CD-Rs do you use?
Old Apr 23, 2008 | 01:28 AM
dfwman's Avatar
I have a 2005 G35 Sedan and am trying to get the factory radio to play my MP3 CDs (burned onto CD-Rs). I am using Verbatim disks but the player says Check Disk and won't play them.
Am I missing something here? What brand CD-Rs has anyone used which worked fine? Is my cd player messed up?
Thanks!
Old Apr 23, 2008 | 05:10 AM
RaginRaj11's Avatar
I have used a variety of different brands and they have all worked fine.
Old Apr 23, 2008 | 05:27 AM
officerdbag's Avatar
I believe the G35 can't play MP3 discs.. You actually have to make it a music CD.
If you are making them real music CD's then I think your CD player is messed up. I've used everything from top of the line brand names all the way down to non name CD-R's and they've all worked.
Old Apr 23, 2008 | 08:54 AM
Beebo's Avatar
Originally Posted by ninous26
I believe the G35 can't play MP3 discs..You actually have to make it a music CD.
05+ can
^+1
Old Apr 23, 2008 | 11:03 AM
dfwman's Avatar
It should play MP3 files since it has MP3 printed right on the face of the radio. I called Infiniti and they said it should also.
My factory radio must be screwed then. If I burn the full size music files onto the CD-R, it plays fine, but it has "Check Disc" if I burn MP3 files on it. I was hoping it was going to be an easy fix that someone else has done, but I guess it needs repaired.
Thanks for your replies!
Old Apr 23, 2008 | 11:07 AM
06g35meister's Avatar
i would test the CD on another MP3 player to be sure its youre car not youre computer. Just to be sure before you lose youre car for a day. See if someone around you has a DEDICATED MP3 player, cause youre comp obviously will, even if the head unit wont.
Old Apr 23, 2008 | 11:11 AM
Hi-TechG35's Avatar
I've always had luck with TDK CD-Rs. I get the 52x 80min 700mb ones.
Old Apr 23, 2008 | 11:14 AM
dfwman's Avatar
Anyone in Dallas around George Bush and Dallas North Tollway?
I have also tried the burned CD-Rs on my home DVD player, and they play fine on it also. I guess buying another spool of CDs is cheap, so I might try to get another brand and see what happens.
Old Apr 23, 2008 | 11:27 AM
brand doesnt matter i guarantee it.
Old Apr 23, 2008 | 02:01 PM
Yea, its pretty much all the same thing.
Didn't know about the 05+ MP3 thing though.
Old Apr 23, 2008 | 02:44 PM
bokja's Avatar
memorex are the best one supposedly
Old Apr 24, 2008 | 12:08 AM
jlin615's Avatar
From my experience, CD-R brands dont really matter. Try burning at 8X speed.
Old Apr 24, 2008 | 12:41 AM
ypahuboy's Avatar
i always used tdk. never had any problems with music cds when i had the stock deck.
Old Apr 24, 2008 | 12:55 AM
elayman's Avatar
check the burn speed, and if you're putting them in the 6cd changer in the trunk (idk if they did this in coupes) but the trunk cant play mp3s only the headunit.. just clarifying
Old Apr 24, 2008 | 01:30 AM
FlSHRFun's Avatar
Stopped using CD-R's a long time ago. AVIC-D3 + CD-i200 + iPod = No more CD's.
