Need help please : Questions about double din conversion install
Old May 10, 2008 | 01:44 AM
cv5boi's Avatar
Lightbulb Need help please : Questions about double din conversion install
I have searched around the forum only find how to install the double din but no wiring instructions. I have a 04 g coupe with navi and the stock bose system. Im going to put a jvc KW-AVX800 7inch screen. and use this harness METRA 70-7551. will this be a wire up plug and play or do i have to splice the oem wire lines? any suggestions? or tips? appreciate it thank you all
this screen
info
http://www.crutchfield.com/S-JLQnFET...05AVX800&tp=75
this harness
Old May 10, 2008 | 10:31 AM
Gilley's Avatar
I haven't used that kit, but I think the other wires should connect to the JVC wires and everything will then plug into the OEM harness.
You will need a PAC-JACK steering wheel interface if you want to keep the steering wheel controls. You will also need a Nissan antenna adapter.
Even though you don't think you have a power antenna, connect all of the wires on the Metra harness to the appropriate wire on the JVC. The antenna has a powered booster that needs to turn on.
jsimonk
Dec 22, 2023 03:49 PM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
EPG35
Aug 16, 2015 04:52 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
