Help with coolin fan..
Old May 21, 2008 | 03:29 AM
nyqueenz's Avatar
Question..
I wanna run a 80mm cooling fan on my sub box that cool the amp set up which will be inside..
How can I power the fan on a 12 volts power supply?
Should I go to radio shack to see if I can do a circuit board of some kind?
Any help will be get...
Old May 21, 2008 | 08:04 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
couldn't you just splice it off your amp power wire OR run it off your fuse block?
doc
Old May 21, 2008 | 01:31 PM
redwillow's Avatar
20 Year Member
^^^^^^^^^what doc said....
this guy sells good fans that are run off of 12v DC & made to go into a cabinet:
http://search.ebay.com/_W0QQsassZdrmckenzie
Old May 21, 2008 | 01:36 PM
Meatshackle's Avatar
Deep Sea Moderator
I ran the 18awg wire right into the same place on my amp I ran my 4awg. I also installed a relay using the remote/turn-on wire for both of my fans.
Definitely get fan(s) that run off of 12v.
Old May 21, 2008 | 06:32 PM
nyqueenz's Avatar
could I just run the 18awg wire to the power off port of the capacitor?
a diagram would help if anyone could imply one please..
da champ
Florida G Club
Jun 23, 2010 09:36 AM
