Troubleshooting Help: Audio Electrical Noise
Old May 28, 2008 | 10:37 PM
davidr's Avatar
I could use some help troubleshooting what seems to be some sort of electrical noise that is feed through my speaker system. This is completely random...It occurs when the key is switched on bat power, the motor does not have to be running. It is also fed through the audio system when the audio system is powered off. The FM stations often do not work at all like they almost loose signal altogether? I was thinking a ground issue although all is stock but found nothing, took apart the dash and inspected all connections and all is well. I would suspect its going bad as its intermittent but puzzled as i hear the feedback and tone when it is powered off. any ideas would be much appreciated. Thanks - 2003 G35 Sedan
Old May 29, 2008 | 08:15 AM
Gilley's Avatar
Is the audio system stock?
Do you have the Bose system?
Old May 29, 2008 | 10:20 AM
davidr's Avatar
Yes the audio is a stock, non bose system, just the basic system.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
dcsbh1
Oct 1, 2015 03:15 PM
