Tapped into wires for sub, subs hitting out of phase above certain volume
Old Jun 17, 2008 | 05:42 PM
acr's Avatar
acr
Tapped into wires for sub, WTF IS GOING ON
I just tapped into the pre-BOSE amp wiring to add a sub to my 05 G35x. These are the wires I tapped into:
Right Rear Speaker
+ BLUE
- PINK
Left Rear Speaker
+YELLOW
-BROWN
What I did is splice the ends of RCA wires into these wires. Just to make sure the connections were good before closing everything up, I ran an RCA from my Infiniti to my other vehicle, and plugged it into its mono sub amp. Here's what happened:
<18 volume subs play normally
19+ volume subs are hitting out of phase, doesn't sound like music, just random hits. Almost like bass static.
I was like WTF so I played some test tones on my iPod in the Infiniti. Up to volume 18, everything sounds normal. With each incremental increase in volume up to 18, the subs get proportionately louder. Then, when I hit volume 19, the subs get MUCH louder and sound like they are clipping or something.
It isn't the amp or the subs, because they play normally in my other car at any volume.
Any experience with this? I'm completely mystified.
Old Jun 20, 2008 | 05:01 PM
Gilley's Avatar
Try reversing the polarity on one of the subs and see if that helps.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
g.spot
May 9, 2016 10:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
