12v Constant, where can I find it?
Old Jun 20, 2008 | 11:19 PM
brikkman's Avatar
hooking up my GEX-P920XM xm tuner. Its working, however, I have the power hookedup to the accessory so I loose my presets when the car is turned off. Found out that i need to connect that to 12v constant power. Anyone have suggestions hwere to tap into it at? Side driver side kick panel if possible.
I found a couple of hot wires, but I think they are providing too much power, it makes the xm cut off and on constantly.....
Any help is appreciated..
Old Jun 20, 2008 | 11:31 PM
Gilley's Avatar
You should have a fuse on that power wire.
A constant on can be found at the fuse panel on the left side of the car.
Old Jun 21, 2008 | 07:40 AM
brikkman's Avatar
Yeah, I have one up there...Do i just plug it in with the fuse that's already there?
Old Jun 21, 2008 | 08:38 AM
Gilley's Avatar
I would use an add-a-fuse at the fuse panel. You can get them at the auto parts store.
Old Jun 21, 2008 | 10:04 AM
brikkman's Avatar
ok, I'll check it out
is that like a doublestack fuse that i can tap on to the end of it?
Freeman186
Sep 6, 2023 10:07 AM
cmesidewayz
Sep 29, 2015 09:28 PM
zcherub
Sep 10, 2015 12:03 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
G35CO
Sep 4, 2015 09:27 AM
