Trying to do an aftermarket amp/subs install for the coupe...got a question.
Old Jul 4, 2008 | 05:39 AM
Screamin Cobra's Avatar
I've done plenty of searching on this site as well as other sites and did me no good for what I am looking for.
Basically I am trying to install a Kicker amp and 2 12"s in the G. I have the amp kit with a PAC converter and I believe thats all I need to do this install. I just need to know which and where the wires are that I splice/tap into for the PAC converter. Also, do I need to run the remote wire from amp to the stock Head Unit? I have an 04 svt Cobra and the install for it was simple because the speakers and amps were right behind the seats on top. I figure you guys would know! Thanks in advance,
Andrew
Old Jul 4, 2008 | 09:46 AM
cRaCKwHoRe's Avatar
I'm assuming reading this that you have the stock HU? Do you have Bose system? If so, this post should help: https://g35driver.com/forums/showthr...light=bose+amp
I'm not sure what a PAC converter is but if you have the stock Bose system you need to tap into the wires off the amp in the trunk. If I'm totally off here sorry LOL.
Old Jul 4, 2008 | 03:22 PM
Yes, stock head unit, stock bose system, speakers, amps, etc. All stock. Just adding an amp and sub. Thanks for reply, will check out link.
Old Jul 4, 2008 | 03:59 PM
acr's Avatar
acr
I'm guessing you're referring to a PAC Line Out Converter. You don't really need it for the install. All you have to do is splice RCAs into the factory speaker wiring at the BOSE amp. The PAC SHOULD work, but it's unnecessary since the signal you're tapping into is already low level.
Old Jul 4, 2008 | 04:18 PM
Oh alright, I'll just use the pics in that thread. What about the remote wire?
Thanks for the help guys.
Old Jul 4, 2008 | 05:38 PM
Gilley's Avatar
The audio signal from the Bose HU is low line level before it enters the Bose amp, so no LOC is needed, as acr stated.
There is a sticky thread titled "DIY: Add a sub to your Bose equipped G35 Coupe" that will show you how. https://g35driver.com/forums/audio-video-electronics/101293-diy-add-sub-your-bose-equipped-g35-coupe.html
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA081024
Aug 18, 2015 07:03 AM
Team STILLEN
Aug 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
