Dd Install And Rear Air Problem
Old Jul 12, 2008 | 11:17 PM
culater's Avatar
I just installed a dd radio in my 03 G35 with the JDM kit. Now the air that flows through the console does not flow the same. I also have the factory navi but now it will not pop up since there is so much pressure from the install. Can someone help with this issue? I also need a good place that can help with adding my dual climate control switch to the new JDM A/C control in the ATL.
Old Jul 13, 2008 | 09:10 AM
Gilley's Avatar
How does the air not flow the same?
Disassemble the trim piece and reassemble it. Something isn't fastened correctly.
You can change the dual climate yourself with a cheap soldering iron and a little solder. o you actually use the dual climate control? I switched my button and I never use it.
Old Jul 13, 2008 | 11:42 AM
culater's Avatar
That is the same thing I told the installer about the rear air flow. I will check this out. I am thinking of changing the switch myself since I can not find anyone to do it for me. No one has the small tip.
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
justgotg35
Jul 19, 2015 12:33 PM
Soumilg
Jul 18, 2015 12:33 PM
