Help and opinions on existing equipment
Old Jul 17, 2008 | 03:05 PM
finagle69's Avatar
I posted this on Myg37.com, but figured I may get more replies and opinions here.
Hey guys.
I'd like to add a little more bass (or a lot more ) to the stock system, but at a minimal cost... like less than 2-300 dollars.
I have some existing gear from earlier cars that I'd like to make work, but I need some experts to chime in.
What I have:
(1) Alpine 503 Amp. Manual in PDF
(2) JL 12W0 8-ohm. Manual in PDF
I currently have an enclosure sized for a Yukon. Obviously it won't work, but I can make another one that will fit in my car.
So my question is this: Could I feasibly use my existing components? If so, what additional equipment would need to be purchased? Wiring kit for hooking up to the battery for sure, but I'd like to keep it as simple as possible for hooking up to the sound signal. This is where I need some assistance.
Should I do one or two subs with my equipment? knowing that the subs are 8-ohms, would one really work? I'd like to have SOME room left in my trunk. lol.
I'm not trying to win any competitions or style points. I know this stuff is old, but it still works and sounds good for what I like.
Thanks in advance for the help guys!
Old Jul 17, 2008 | 04:08 PM
Gilley's Avatar
I haven't read about anyone tapping into the G37 sound system but it's possible. Maybe the service manual will tell you where the audio signal are locate.
Old Jul 17, 2008 | 09:29 PM
finagle69's Avatar
anyone else?
Old Jul 18, 2008 | 12:21 PM
35gsleeper's Avatar
First Go Thru Your Manual..it Will Tell Where To Locate The Wiring System In Your Car..you Have Everything You Need Except A Perfect Enclosure, Plus You Will Only Need One Sub In The Car Two Is Over Kill..trust Me!
Old Jul 18, 2008 | 12:27 PM
finagle69's Avatar
cool. can anyone comment on the technical aspects of one 8-ohm speaker being hooked up to that amp? and how would the connection be made with what settings on the amp? this is where i need help.
Old Jul 19, 2008 | 09:20 AM
matthimself's Avatar
that amp is only 200w bridged at 4ohms.. wich would mean you have to run both subs to get to 4ohms... i would just sell the subs and get a single 10 or 12. This would be close to your budget espically if you sold your old gear.
http://sacramento.craigslist.org/ele/759713604.html
as far as getting a signal i would i think you could use a line out converter and just tap into your rear speakers.
Old Jul 19, 2008 | 10:54 AM
Extreme G's Avatar
John' just get a converter and tap into your speaker . That's what i did to my 07.
Old Jul 19, 2008 | 12:38 PM
finagle69's Avatar
Originally Posted by matthimself
that amp is only 200w bridged at 4ohms.. wich would mean you have to run both subs to get to 4ohms... http://sacramento.craigslist.org/ele/759713604.html
I'm not so sure that's true...
if you look at the specs on the side of the box in the listing you posted. that amp is only 175W @ 4ohms at 14.4V
if you look in my manual for 14.4V, it shows a few different wattages for 4ohms, max being.. 500W at 1khz. but the part where i'd be using it is 20 - 20khz, and it shows 300W max at 14.4V, so it's actually better than the amp shown in the listing.
so at 8ohm, that would be 150W, which is in the "optimum" zone in the JL manual...
IDK, i may just try to hook it all up and see how it sounds. i guess the only thing i have to lose is cost of material for a box...
Old Jul 19, 2008 | 03:08 PM
not totally sure how it works when u go higher w. ohms but when you go lower some amps can't handle a 1ohm load and it will send them into protect mode.
Old Jul 20, 2008 | 02:26 PM
finagle69's Avatar
now i'm thinking of buying a 10w6v2 and 500/1 on the cheap from craigslist. lol.
Old Jul 21, 2008 | 07:20 AM
that's what I would do....I have that w. 2 10w6v2 in my truck and it sounds really good. how much are they going for?
Old Jul 21, 2008 | 11:26 AM
finagle69's Avatar
crap, should i have gotten two of them?
i got the 10w6v2 for 180 and the 500/1 for 220. not too bad i guess. the guy who sold me the speaker still has two more 10's
Old Jul 21, 2008 | 08:47 PM
i dont think you need 2... the only reason i have 2 is becasue i bought them used already in a box.... 2 would sound really good if you had either a 1000/1 or another 500/1. I like how mine sound but sadly my front speakers get 225 watts a peice and my subs get 250 watts, and sometimes i wish my subs were louder. But 500 watts to 1 will sound really good.
Old Jul 21, 2008 | 09:53 PM
finagle69's Avatar
cool. Thanks for all the insight man.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
prinny
Nov 22, 2015 11:07 PM
