recommendations on a budget
Old Sep 14, 2008 | 12:44 PM
MikeGrote's Avatar
Originally Posted by sfgr415
JL Audio 10W3v3
with which amp?
Old Sep 21, 2008 | 11:08 PM
MikeGrote's Avatar
is this too much power to have without an capacitor? i dont want to stress my car's electrical system or shorten the life of any of its components. would run at 2ohms.
amp: http://www.sonicelectronix.com/item_...r+ZX750.1.html
sub: http://www.soundsolutionsaudio.com/p...s/icon/10.html
Old Sep 22, 2008 | 05:17 PM
-AR-'s Avatar
check out this site
http://www.edesignaudio.com/
Old Sep 22, 2008 | 07:02 PM
MikeGrote's Avatar
Originally Posted by -AR-
check out this site
looks like you can get a 1200 watt system pretty cheap there. nice find. i need a 10" sub and prefer. not that much power.
Old Sep 23, 2008 | 08:26 PM
MikeGrote's Avatar
what do you guys think of refurbished amps off ebay? more specifically a kicker 750.1 or 1000.1?
Old Sep 24, 2008 | 03:47 PM
MikeGrote's Avatar
i think im gonna try and put a 10" icon in a drivers side coupe 4080 box with an amp in the 750-1000 range. anyone know if the icon will fit? if i need a spacer, where do i get those at? thanks
Old Sep 24, 2008 | 07:53 PM
MikeGrote's Avatar
just called the guys at 4080enclosures.com and he said some ppl have put the icon in the drivers side box so i just thought id let everyone know. thats what he said anyway, ill verify when i put the system in my car.
Old Sep 26, 2008 | 09:43 AM
Deebo16's Avatar
check out this site
Really look and check them out. You can find a decent amp and sub combo for under $400 I'm sure. They do a lot of testing and give you recommendations on what to get also.
Old Sep 26, 2008 | 10:27 AM
Nismoboy's Avatar
Alpine Type-R 10" Dual 4ohm Sub - $115
500W RMS Handling
Freq. Resp. - 26hz-500hz
http://www.onlinecarstereo.com/CarAu...roductID=14952
Total Mobile Audio T500.1 -$159
A JL Audio Company
500W RMS x 1 @ 2ohms
http://www.onlinecarstereo.com/CarAu...roductID=18636
~$274 Shipped for both!
This will be clean and loud for sure! Plus its all very good quality! Good Luck!
Old Sep 26, 2008 | 12:32 PM
redlude97's Avatar
Elemental Designs 11ov.2/ED nine.2x $~350. Comparable to a JL 10w6/500/1 setup with lots of extra money to spare
MikeGrote's Avatar
500W RMS Handling
A JL Audio Company
nismoboy,
i kind of have my heart set on this combo, which i can get for about $500, unless you think thats too much power for my electrical system. thanks!
sub: http://www.soundsolutionsaudio.com/z...&products_id=7
amp: http://www.soundsolutionsaudio.com/z...&products_id=6
Old Sep 26, 2008 | 12:59 PM
Nismoboy's Avatar
Originally Posted by MikeGrote
nismoboy,
well i'm running a jl audio 500/5 amp and i've already had to replace my alternator and battery once.. but i'm not really sure if its due to the amp, wear and tear, my supercharger or everything put together lol
but since the replacement about 2 years ago.. its been perfectly fine
it all depends on how you're gonna wire the sub also 4,2 or 1 ohm.. and the amp your looking at is rated 300w, 600w and 1000w respectively...
my opinion.. anything over 500watts.. look into a deep cycle battery, 1+ farad cap and maybe even a high-output alternator just to be safe
Old Sep 26, 2008 | 01:21 PM
MikeGrote's Avatar
i planned on 1ohm. how much are high output alts for these cars? for some reason i think i remember seeing the alt underneath the car when i was changing oil and thinking it would be a pita to change
Old Sep 27, 2008 | 02:26 PM
MikeGrote's Avatar
second guessing myself, may go this route at 4ohms instead to save money and less amps pulled from the car battery
amp:http://www.partsexpress.com/pe/showd...number=267-123
sub:http://www.partsexpress.com/pe/showd...number=295-462
125+200= $325 total
Old Sep 27, 2008 | 04:57 PM
  #30
Nismoboy's Avatar
125+200= $325 total
yea that should sound pretty decent.. i've haven't heard about dayton subs in awhile.. they're pretty good from what i can remember... sounds like you got a plan! great find btw! good luck!
