remove reat seats in a sedan?
Old Sep 29, 2008 | 03:04 PM
blazeplacid's Avatar
I have an 04 sedan and im thinking im going to install an amp tonight.
Do the rear seats just lift out like most cars or is there a trick?
also, whats the best way to run the power wire into the car??
Old Sep 29, 2008 | 03:32 PM
ttrank's Avatar
Grocery getter
Mine is an 04 non-premium (does not recline)
Bottom has two pulls on each side to release it. Lift and remove.
The back side comes out is pieces. There are a few bolts at the bottom of each side and a hook on the higher side. Remove the bolts and lift up to remove.
Power wire can be run through one of the grommets behind the battery, down the pass side and into the trunk. Remember to run the RCA's down the opposite side as the power wire.
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
Xanthan Gum
Aug 6, 2015 10:49 AM
si_driver
Interior
Jul 25, 2015 09:22 AM
