Question for those with a 07+ G
Old Nov 18, 2008 | 02:27 AM
NewGuyG35's Avatar
Do I have to remove the entire door panel in order to get to the speaker on the door? There is noticeable rattle noise coming from that area when I'm listening to music at full blast. I wanted to get in there and see if there is anything loose.
Old Nov 18, 2008 | 05:08 PM
UCFBrian's Avatar
I just had the same problem with my 07 sedan, a rattle coming from the drivers side door panel around the window controls. When I upgraded the door speakers I found the cause, there was a bracket inside the door panel that the screws were coming loose on. Most of the parts on the door panel are screwed together. The door panel is easy to take off all you need is a small screwdriver and a 10mm nut driver.
Old Nov 19, 2008 | 12:05 PM
NewGuyG35's Avatar
Yeah, I forgot how they removed the panel when they installed the tint. I guess I'll get someone who knows to take a look at it.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
