How do you wire the OPUS PSU to the car?
Old Jun 1, 2004 | 02:27 PM
afr0puff's Avatar
Supa Dupa Moderator
OK, three connections need to be made...
1. Battery Pos
2. Ground or Battery Neg
3. Ignition
The first two are fairly obvious, but how do I tap into the ignition? Does this mean I can just tap into any wire that becomes "hot" only when the ignition is in the ON position? Also, is there a need for a fuse?
http://www.anythingbox.net
Old Jun 1, 2004 | 02:51 PM
RamboRami's Avatar
G35driver.com Moderator
Re: How do you wire the OPUS PSU to the car?
can you just tap into the headunit's ignition wire?
the PS didnt come with instructions? i would call opus and pitch.......i mean, b... [img]/w3timages/icons/smile.gif[/img]
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Jun 1, 2004 | 03:45 PM
afr0puff's Avatar
Supa Dupa Moderator
Well, yeah it did. Basically the stuff above. But they assume the owner has some basic knowledge of cars, which is obviously not the case here. ;p
Old Jun 1, 2004 | 08:47 PM
god_of_cpu's Avatar
StreetDeck.com Developer
You can also tap the power wire for the BOSE amp in the trunk if your putting it there.
You definitly need a fuse for the battery line, but since the OPUS shouldn't ever try to draw any real current from the iginition line, you shouldn't need a fuse for it, but it certainly wouldn't hurt anyting to put one on.
Old Jun 1, 2004 | 11:05 PM
dtrip35's Avatar
afro can you take some pics along the way? i'm going to be doing this soon and like you I'm a newb. so any help would be great
Hasanbaloch
Feb 29, 2024 08:45 PM
Karran Dhanroop
Aug 2, 2015 08:22 PM
Rehman2009
Jul 27, 2015 03:23 AM
Texasscout
Jul 24, 2015 03:43 PM
stay_tuned
Jul 21, 2015 07:09 PM
