Pioneer DD + PAC swi-ps + ITouch = ISSUES 04 coupe
Does anyone here use a Pioneer DD+ PAC swi-ps + ITouch? I cant change tracks forward (but i can change the tracks Backwards)via my steering controls. Also when I had my orignal bose system I was able to change PRESET radio stations via the steering wheel controls now it seeks it doesnt do PRESETS...Is there a way to change it to presets?
Thanks
Jeff DG 04 coupe
Thanks
Jeff DG 04 coupe
it's a programming thing...
I have the same track up issue, the problem is that the resistors with the steering wheel controls are just on the edge of the 5-10% tolerance that the track up needs. It will work every once and a while. it bugged me at first but I like my DD really easy to switch tracks, (next track is about finger length from 5th
as for the presets thing... you've changed the system and whoever installed the steering wheel controls they set it up for the most common procedures, track up, track down, vol up, vol down, etc.
)as for the presets thing... you've changed the system and whoever installed the steering wheel controls they set it up for the most common procedures, track up, track down, vol up, vol down, etc.
