Wiring Help...!
Old Jun 7, 2004 | 02:48 PM
GoSooners's Avatar
Wiring Help...!
Okay guys, I just wanted some confirmation/suggestions before I install my wiring later this weekend. I'm going to run 2 gauge wire from the battery to the rear to a distrubution block in the rear. I plan to run it along the driver's side by the door, just like in the DIY by nycg35. I'm going to keep the stock HU for now.
1) Where should I tap the remote wire in? Is there anywhere in the rear pre- or post- Bose amp? I'm trying not to disassemble my front dash if possible.
2) I've done research and discovered that my JL Audio 500/1 amp does not need a LOC. Can anyone confirm this? It can take high (speaker-level) inputs at the flip of a switch on the amp. Thus, I will be purchasing a "wire-to-RCA" adaptor from JL Audio where I will plug in my RCAs. The question is where should I splice in? This amp will be for a pair of JL Audio 10W3v2 subs. I know of 2 locations: rear "subs" (wire from Bose amp to 6x9s) after the Bose amp, OR before Bose amp? Which is optimal? Lesser noise/hum/hiss... If I spliced into the rear subs, I'll only be getting a low-pass signal, correct? So if I wanted to preamp out of the 500/1 later on into another amp for components, I'd still wouldn't get a full-range signal? Does anyone have the link to the wiring diagram? It is a bit confusing.
3) Does the Bose amp have any effect on the navigation system? I'm asking because I don't want to lose the voice prmopts and "mute front speakers" feature when I install my new system. So this relates to my previous question about where to splice (in the case that the Bose amp affects this).
Thanks ahead!
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
