Problems installing dd kit
Old Jan 12, 2009 | 12:15 PM
Heinz's Avatar
I am installing the Metra kit in my 2004 G35 Coupe, and got the 7550 wiring harness.
I have connected this to the OEM 225w Bose amp, but i got no sound, there is two cables on the 7550 wiringkit i dont know where to connect, and its the black/white and Blue/white cabels, the amp turn-on, and the amp ground.
Please help.
Old Jan 12, 2009 | 12:41 PM
TroysG's Avatar
don't worry about those... fold them over and tape them up. those aren't neccessary, just connect the blue white from the deck harness to the blue on the 7550 harness
Old Jan 12, 2009 | 12:45 PM
Heinz's Avatar
My deck harness doesent have any blue/white wire, but it has a yelow/white that is marked EXT AMP, and the 7550 harness blue wire is marked power antenna.
Old Jan 12, 2009 | 01:09 PM
Heinz's Avatar
Tryed to connect the blue/white to the yelow/white, but still no sound, seems to me like the amp does not get any power
Old Jan 12, 2009 | 01:39 PM
TroysG's Avatar
what deck are you using.
try taking the yellow white to the blue of the 7550 - the power antenna is also the amp turn on wire. I have no clue why the 7550 is labelled otherwise
Old Jan 12, 2009 | 01:48 PM
Heinz's Avatar
Bought the deck from China, so it has no name, but it has all the intersting stuff like bluetooth handsfree, touch screen, dvd, radio, navigation, sd card reader, usb port, etc
So i dont need to connect the black/white cable, called amp ground?
Old Jan 12, 2009 | 02:37 PM
Heinz's Avatar
Found out about it, had to set up the deck player menu to ext amp, and i used my yelow/white cable connected to the blue/white cable, now it work like a charm.
But one thing, i think it is extremely loud, and mabe i hear some distortion.
Old Jan 12, 2009 | 02:54 PM
TroysG's Avatar
if it's distorting, don't turn it up so loud and adjust the bass and treble settings accordingly. - mainly the bass
Old Jan 12, 2009 | 02:59 PM
Heinz's Avatar
Thanks alot for your help, i`ll give you the adress to this China web shop, lots of cheap dvd players with navigation, etc there.
www.autodvdgps.com
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
attarday
Jul 15, 2015 04:03 PM
