Radar Detector and Mikes Mount
Old Feb 4, 2009 | 09:53 PM
jamesgrover's Avatar
I have 2 questions. I have an Escort x50 with Mikes Mount. Unfortunately, I don't have the premium package in my 04 6mt.
I am going to hardwire the radar detector. i have the Escort Direct wire kit. Does anyone know which wire specifically I can splice into for power at the fuse box? The kit came with an easy clamp splice, but I don't know which wire is a switched 12 v source. Yes, I know I can get the multimeter out. Yes, I know I can get the add fuse from Pep Boys... But, I am impatient. Its too late to get the add fuse kit from PepBoys, and I don't feel like digging around my fusebox. I was hoping that someone that has used this direct wire kit could tell me which wire they used for a switched power source.
The second question: I don't have a powered mirror. It does not have auto dimming. It has the old school flip at the bottom of the mirror. With the Mikes Mount in place, I won't be able to use the flip. Has anyone removed this from their mirror? I was hoping I could just pry it out, but no luck so far. Is there an easy way to remove this flip?
Old Feb 4, 2009 | 09:58 PM
suicidesam's Avatar
****defected****
i got the power from the drivers side kick panel.
Old Feb 4, 2009 | 10:05 PM
Do you recall which wire? What color was it? It would be great if I could clamp onto the same wire and be done.
Old Feb 4, 2009 | 10:11 PM
suicidesam's Avatar
****defected****
nah i don't remember sorry
Old Feb 4, 2009 | 11:42 PM
TroysG's Avatar
do you have a multimeter or a *god forbid* test light?
Old Feb 5, 2009 | 08:34 AM
I wanted to do this quickly and easily without getting dirty. I know its not a tough install. It should only take 10-15 minutes or so, but I only wanted to spend 2 minutes. My bad. I'll stop being lazy now.
Anyone ever removed that Mirror Flip? I don't see anyway to take the mirror apart. I didn't see any screws.
Old Feb 5, 2009 | 08:56 AM
GreenGoblin's Avatar
The goblin resurrection
The flip mirror can be detached via a hex or allen I can remeber from the windshield.
Old Feb 5, 2009 | 09:33 AM
fishhouse's Avatar
i have a Mikes Mount with Invisicord now. but, in previous vehicles (American-made that don't cut the cigarette lighter power when the car is off), i've used the fuse method. picked a fuse (for an accessory like the stereo) and then just done a dirty wire twist around the fuse and grounded nearby. or they make little fuse piggyback thingies that work even better and are less crud.
for my previous non-American cars (nissan/infiniti/acura) i've always just wire tapped/spiced right into the cigarette lighter's power wire. you can easily access this in the G's usually by just lifting the plastic trim under your head unit - around your shifter. a quick tap and nearby ground is all it takes.
your hardwire kit might be made to work with a fuse instead. did it come with one of those little piggyback things? if so i'd just pick one like the cigarette lighter and use that fuse.
Old Feb 6, 2009 | 09:31 AM
let me clear some things up.
Yes, I'm lazy... But, I'm not ridiculously lazy. I have a multimeter and have installed several car audio systems, so I know my way around electronics... That being said.. My hardwire kit came with one of those blue clam shell splicers. Sure, I could use the multimeter to test the fuse locations, but I was looking at the bundle of wires that came from the fuse box. I couldn't tell which wires went to which fuse. I didn't want to take the kick panel off... I just wanted a direct wire to splice into. Long story short, I went to pep boys and picked up the add circuit interface. Worked like a champ.
Part 2.
Has anyone removed that flip lever from their mirror? I am referring to the lever that you flip at night when someone comes up behind you with their high beams. I have a Mikes mount and can't use it anyway. I saw the hex nut, but as luck would have it, I can't find that size wrench (looks like another trip to Pep Boys).
Old Aug 24, 2009 | 11:13 PM
BradBlick's Avatar
So... lol looks like I am the lucky guy who is nor lazy or an experienced person in the fiield of fuse boxes.... I have no multimeter or any of these tools... BUT I too would LOVE to know which wire to tap into...
I spent all day looking for a diagram or a listing or something of that sort that I could read from but still no luck. I figured I'd just take a gamble and tapped one.... When I grounded it, my hazards came on
So if anyone could tell me which color wire to cut!! (Sounds so dramatic) That would be fantastic.
Thanks!
Edit - PS .... I'm driving an 06 G35 Coupe =)
Old Aug 25, 2009 | 08:39 AM
blazeplacid's Avatar
you guys are making it to hard
look in the fuse box for the cig lighter fuse
use a the fuse that is there (blue 15amp) and use a t tap, find a good ground, your done
Old Aug 25, 2009 | 08:47 PM
BradBlick's Avatar
what exactly is a T tap?
Plus I just bought 2 different "Add a Circuit" things today neither of which fit my fuse box.... I'm wondering why this is so freaking hard for me... I'm very tech savvy.. I even run a damn geek squad lol.
Old Aug 25, 2009 | 09:26 PM
you need a low profile t tap, since our fuses are low pro
google : t tap
Old Aug 26, 2009 | 04:11 PM
BradBlick's Avatar
So I've already got a handful of T-Taps.. I used one a few days ago and tried to guess which wire to tap after a full day of NOT being able to figure out which wires went to what ... and it was my hazards, basically when ever i tapped the grounded end it would toggle the hazards...
Infiniti said they'd charge me $50 to install this - This is nuts it really can't be THIS hard.
Old Aug 26, 2009 | 04:13 PM
find the fuse labeled
"cig lighter"
Like I said it will be a blue 15 amp fuse.
Does your fuse panel cover not have the diagram that shows you the layout of the fuse panel?
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
Claudiu
Sep 24, 2015 01:12 PM
