I have a 07 coupe g35 bose system. I just want to replace the front speakers along with the tweeters. Can i use the Polk MM 6.5 inch? I don't want to change anything else. Do i just need the spacer along with whichever speaker i purhcase? what is the best speaker i can use without adding an amp or anything to the bose setup. and is there a DIY thread on how to replace these speakers and tweeters?
Thanks
Thanks
Realistically if your gonna add any kind of decent speakers you need an amp
The bose Hu will run 4 ohm components but at half the rated power
I dont know the power rating buy im asuming its 25-30 rms at 2 ohm.
So you would be looking at 10-15 rms@ 4ohm
You will need a spacer also to clear the window
