Anyone tried making their own NIS2 or similar?
Old Mar 12, 2009 | 11:36 AM
MidnightG35X's Avatar
Has anyone attempted to make their own NIS2 or similar mp3 player adapter? I have never seen anyone take the cover off the NIS2, but it looks like the installation is only 4 wires that connect to the factory headunit. Seems like it might be a simple operation...
Old Mar 13, 2009 | 10:59 AM
Anyone?
Old Apr 22, 2009 | 03:41 PM
bmanG35's Avatar
Usually the less wires the more complex. I will most likely be looking into it.
Commands are transmitted using a serial link, to contruct an interface you need to reverse engineer:
* Physical layer, Serial layer, Protocol structure, Commands structure.
Old Apr 22, 2009 | 04:55 PM
I'm not sure if there is serial communication on it or not. If there is, its not worth the time required for me to reverse engineer it. I'm pretty certain 4 of the wires are just standard line level outputs, but I'm not sure if the control lines are CAN lines or just simple enable lines. If I don't get text output on the radio, I don't care. If I can just throw an enable line and get it to work, fine with me!
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
crysis
Aug 24, 2015 07:57 PM
Phenomenon9
Aug 9, 2015 01:34 AM
