Diamond Audio Sub...only hitting when...
Old Mar 17, 2009 | 03:03 PM
nchima's Avatar
I push in the sub, jus a bit...then, it starts hitting like mad crazy. I messed with the EQ settings, and every other setting. It use to be working just fine, up until the last week, then it came to my attention. The subwoofer wires were professionally done, but...the wire running to the actual subwoofer(speaker wire?) was a little loose. I tightened it up, but still problem occurs.
I read online that maybe it isn't drawing enough power, I have a cap, but never got it installed because I'm missing one part. It's a single 10 hooked up to a (weak) 600 watt HiFonics Amp. So, it basically hits when I push the sub in a little (literally)...should I take sub out of box and make sure the wires are still connected properly?
Thank You
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
the93owner
Sep 28, 2015 10:37 PM
