Incorporating shock sensor to oem alarm on '07 + sedan G's ???
Old Apr 4, 2009 | 11:12 AM
5u30five's Avatar
can this be done? any info will greatly be appreciated. thanks.
Old Apr 4, 2009 | 04:15 PM
Vrod-Mike's Avatar
I used to do it all the time. Just hook the sensors output up to the hood switch input and it should work fine. Just put a diode on it so nothing back feeds into the system.
Old Apr 4, 2009 | 05:55 PM
sfgr415's Avatar
Its pretty much universal. You have to tap into the hoodpin switch input as that triggers the stock alarm.
Old Apr 8, 2009 | 04:45 PM
5u30five's Avatar
what kind of diode are you talking about? pls specify. thank you.
Old Apr 8, 2009 | 05:51 PM
Vrod-Mike's Avatar
You can go to any Radio Shack and ask for a diode. A diode is like a door in that it will only allow a signal to flow one way and not the other. It's probably unnecessary, but I've always use one when interfacing with a factory alarm system.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
teamghost
Jul 28, 2015 04:52 PM
stay_tuned
Jul 21, 2015 07:09 PM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
