Need HELP!! JDM A/C controller issue...
Old Apr 7, 2009 | 10:34 AM
PeterUbers's Avatar
I already searched can't quite figure this one out:
So i did the dual button mod and everything on my JDM (2006 Gx) and installed the F90bt, JDM a/c controller worked fine, F90bt worked as well.
I decided to upgrade to the DNX8120, so I rewired the metra 7551 harness to the kenwood harnesses, etc, and I installed it into the JDM bracket and with the A/C controller.
Now, the A/C controller is NOT working (kenwood works fine): it's stuck at 75 degrees both sides with the driver's side pointing at the feet... NONE of the JDM buttons do anything except the defroster -- and i can hear the relay clicking in the background.
Also -- the lights on the JDM will light up just fine --
Anyone know why this is happening?
Oh, I put all my stock stuff back in (thinking i fried something big) and everything works flawlessly -- factory stereo, factory A/C controller.. everything works fine..
help!
Old Apr 8, 2009 | 05:35 PM
PeterUbers's Avatar
Ok -- so i fried my first AC Controller (had Grubbs overnight me a new one -- had to shell out another $200)
DO NOT DO WHAT I DID .. i'm a complete idiot, i forgot to disconnect the negative battery terminal prior to my installation and i basically zapped the board when i plugged it back in.
ALWAYS ALWAYS ALWAYS TAKE THAT TERMINAL OFF! then do yer electrical work -- then reconnect.
Thanks for listening.
Old Apr 8, 2009 | 08:15 PM
TroysG's Avatar
did you have the car on when you plugged it back in?
I've installed probably thousands of radios without disconnecting the battery.
Old Apr 9, 2009 | 06:27 PM
PeterUbers's Avatar
Sadly, yes... I think it was in the ignition position ...
Old Apr 10, 2009 | 08:08 AM
Gilley's Avatar
If you removed the plastic panel under the steering wheel, make sure the cabin temperature sensor is plugged in.
G35Rican
Jul 31, 2024 01:37 AM
JLee301
Sep 25, 2015 08:46 PM
bigmike
Sep 17, 2015 01:58 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
