which PAC resistors are which?
Old Apr 11, 2009 | 04:48 AM
psycobusa's Avatar
the resistors that came with my pac swi-ps are color coded it seems but they dont tell you which ones are which and i dont have a multi meter. does anyone know which color codes are which?
Old Apr 11, 2009 | 08:51 AM
blazeplacid's Avatar
DMM would be easiest
google ohm color code
Old Apr 11, 2009 | 10:09 AM
djCypher's Avatar
what ohms is it asking for. ill post the colors
Old Apr 12, 2009 | 02:46 AM
psycobusa's Avatar
150 ohm resistor and 47 ohm resistor
thanks
Old Apr 12, 2009 | 02:59 AM
jin22gt's Avatar
I need to get resistor's for my pac-swi-ps. The freaking audio shop didnt use resistors for the install, and the the swi-ps dont work. Where can i buy resistors? does radio shack have resistors?
Old Apr 12, 2009 | 06:44 AM
psycobusa's Avatar
i googled and found this might be helpful.
http://www.csgnetwork.com/resistcolcalc.html
Old Apr 12, 2009 | 03:05 PM
djCypher's Avatar
yes radio shack has almost all of them instock
Old Apr 18, 2009 | 05:53 PM
arch's Avatar
i found my 150 ohm resistor,but the other resistors in the pack are high ohm resistors the only one left is a 41 ohm resistor.can i still use this 41 ohm or should i take a trip to radio shack?
Old Apr 18, 2009 | 07:08 PM
jin22gt's Avatar
I got both 150 and 47 ohm resistors at radio shack(pack of 5 for $.99 for each type of resistors). The resistors are much bigger than the resistors provided with the pac, but seems to work good.
Old Apr 18, 2009 | 08:38 PM
PeterUbers's Avatar
you bought 1 watt resistors, you only needed 1/4 watt resistors... they'll work fine though. No worries
Old Apr 19, 2009 | 04:12 AM
psycobusa's Avatar
the 47 ohm resistor is colored yellow, violet, black. if like mine, you should only have 1 resistor with a yellow stripe on it. look at the second stripe carefully, the violet looks brown unless you look at it under a good bright light source.
Old Apr 19, 2009 | 12:20 PM
arch's Avatar
Old Apr 19, 2009 | 12:51 PM
arch's Avatar
ok it is violet. thanks, so im good. also do i cover the resistors with the heat shrink or just leave em exposed,and do i solder them into the pins or do i splice them into the wires of the nissan adapter harness or the harness from the dnx8120 hu? i have one more issue. i have a 2005 g35x and the diagrams i found show the pin numbers in the terminals. i dont understand how to read them is there a color chart i can use for my install?
Old Apr 19, 2009 | 05:31 PM
jin22gt's Avatar
there are 4 differnt harness behind the stock radio. Look for the harness with 4 wires, thats the steering wheel control harness. I put the resistors on a small board and solder it on to the board, and i solder the wires onto it.
Old Apr 19, 2009 | 06:21 PM
arch's Avatar
does the gold end of the resistors go to the white wire or is it the other way around
