Installation of Satellite Radio
Old Jul 9, 2004 | 02:01 PM
robdado2's Avatar
Before I buy, I want to be sure I won't have any hang ups. Using Grubbs install guides, I did. I have a 2004 G35X. It is pre-wired, I just can't find the wiring harness. I found my Bose amplifier under the rear deck, but I couldn't find the satellite wiring harness. Any help?
Old Jul 9, 2004 | 04:23 PM
Noremac's Avatar
Re: Installation of Satellite Radio
Yes, the instructions are not clear where the harness is!
In the sedan, it is located directly behind the rear seat, toward the passenger side, AT THE BASE of the seat. You will need to entirely remove the one trunk lining piece that extends from beneath the rear deck, folds 90 deg, then goes down behind the seats. I recall there are four of the large push-grommets to remove. There is generally no need to remove the side pieces.
<font color=blue>'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat</font color=blue>
Old Jul 10, 2004 | 02:18 PM
robdado2's Avatar
Thank you. The one panel I didn't remove. I found it, didn't even need to remove pins. took me 20 seconds to find
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 12, 2015 05:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
