CD Player: CHECK DISK!!
Old Mar 20, 2011 | 12:10 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Not sure about lasers in the unit, but the whole radio units aren't compatible.
Not worth the trouble anyway, you've got three very common problems with the radios - mechanical failure of the cd changer, power supply failure ruining the circuit board and disc read failure. Not much reason to fix it when one of the other problems is likely to surface.
Upgrade to aftermarket now that you've got an excuse.
Old Nov 18, 2011 | 09:44 AM
NepTuneZ's Avatar
About 2 weeks ago i became a victim to this horror story. Has anyone found a sure way to fix it yet? I tried the cd cleaner thing (garbage).
Old Nov 18, 2011 | 01:52 PM
Sure way? Get rid of the failure-prone stock unit.
Old Dec 21, 2011 | 05:03 PM
Marc Bynum's Avatar
Is their a better solution to this besides "just replace the crap stock unit"? I really don't have the money to throw away on an aftermarket unit.
Has anyone attempted to contact Infiniti? Has anyone with the problem ever gotten their stock unit to work again?
Old Dec 22, 2011 | 01:58 AM
No. There is no better solution. You can get an (cheap) aftermarket headunit and the cheap metra trim kit for roughly the same price of a repair on the factory unit, but there's 6 common failures of the factory unit and that repair won't fix the other problems, so you'll have to keep dumping money into it if you want to keep it for a long time. For the price of a factory replacement, you can get a decent aftermarket unit and the JDM trim kit. For a few hundred more, you can get a serious upgrade on the headunit and the JDM trim.
Infiniti's well aware of the crap unit but since it fails outside of warranty and isn't a safety feature, they don't care.
Old Dec 24, 2011 | 01:48 PM
Marc Bynum's Avatar
That really sucks! Thanks for the response though. Guess I'll start looking for a double din DVD/Navigation headunit. Really sucks considering I already have factory navigation. Guess I'll just make them fight one another.
Old Jan 4, 2012 | 07:30 PM
slylegend's Avatar
Not to metion its a B**tch to take the damm thing out. At least Infinity could of did us all a favor and make it simple to take out it they are well aware of the these cheap low quaility damm units. ><
Old Jan 5, 2012 | 05:29 AM
gizsf's Avatar
I have replaced my bose once, fixed it twice, and have pulled it out more times than I care to count. Thanks to it, I have also gone through 5 car batteries due to the parasitic draw problem also associated with it. My wife finally felt so sorry for me that she got me to order the pioneer app radio for my bday. You can replace the blose to aftermarket with descent HU and a metra kit. Crutchfield throws in the metra for $100 if the HU is $130 or more. If you use a referal code (pshkw-7ds9v-dqq84) you get another $20 off. Thats $210 shipped w/ harness'/adapters/instructions and no more bose headaches again! If you want steering wheel control you'll also need the Axxess ASWC ($70 at crutchfield or about $45 on amazon). $210-$255 is much easier and even cheaper than dealing with this constant bose headache.
Old Jan 6, 2012 | 02:40 PM
slylegend's Avatar
Thanks bro this was a big help.
jilljann1
Jul 21, 2020 08:12 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Machine Head
Sep 4, 2015 07:22 PM
