Help with Speaker and Power wire interference
Old May 13, 2009 | 10:05 PM
g35boi's Avatar
Hello All,
I recently succeeded in running new speaker wire to the front doors of a 03 G35 Sedan. The problem I am having now is the speaker wires on my right side, passenger side, is running along with the power wire... and is causing a huge amount of whining noise which is most likely due to the power and speaker wire running along the same side. Can someone tell me how they ran their speaker and power wires on the passenger side without the two wires interfering with one another?
Old May 14, 2009 | 07:15 AM
BXG35x's Avatar
ur best bet is run the speaker wire of the driver side. a little bit more work but defiantely no whining noise
Old May 14, 2009 | 08:46 AM
TroysG's Avatar
are your RCAs run on the same side as the power wire?
speaker wire doesn't usually get inductive noise.
Old May 14, 2009 | 06:36 PM
g35boi's Avatar
The RCAs I have are in the trunk, connecting the amp to the LOC, they are not touching any other wires. I am now certain the speaker and power wires are the cause of the interference since static sound can now be heard on the passenger side. I'm trying to figure out the best and easiest way to route the speaker wires from the front passenger side to the driver doors side. Can someone tell me how to get the wires through the center console, carpet without the wires being expose or cause any other problems?
Old Jul 13, 2009 | 04:02 PM
Rickochet's Avatar
Im having tons of problems with my speakers and wire interference also. My left side speakers tend to go out occasionally, and the RCA under the armrest does not work half the time, plus lots of static. Pisses me off for such an expensive car! So i took it in, and they said they will order a new head unit for me. 2 weeks later, I call to see if its arrive. They told me that the guy who ordered it no longer works here, and I need to take the car in again. What BS!
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Mikesta
Sep 10, 2015 05:14 PM
