2003 G35 Sedan stereo power wire, and good ground location
Old May 21, 2009 | 11:24 PM
romeyp's Avatar
I have recently purchased a Avic-F500BT and like it a lot, but to be able to use all of the functions I need to connect it's cradle power cable to a source of constant power, and I also need to find a good location for a brake wire which as I understand it just needs to be grounded. Where can I find a spot for grounding in the car?
My problem is I need to know if I can get easy access to the stereo power wire or would it be best to try to run it to the battery?
It's a good enough GPS system for me, but without these wires connected I don't have access to all of the functions it has to offer.
I am hoping I don't have to take the dash apart other then maybe removing the panel below the steering column which seems to be an easy enough process.
I hope this makes sense.
Any help would be greatly appreciated.
Old May 22, 2009 | 08:44 AM
TroysG's Avatar
don't ground it to the battery you'll have all sorts of issues with that. There are metal/chassis brackets all over the place in the G. connect to those.
Old May 22, 2009 | 09:12 AM
romeyp's Avatar
Thanks for the reply.
I'm glade you told me that because I would have done that not knowing any better.
I'm a PC guy but a complete newb when it come to working on autos.
Would you be able to tell me where one of these brackets would be located so I know what I'm looking for?
Thanks
Old May 22, 2009 | 10:07 AM
blazeplacid's Avatar
you COULD wire it to the battery but as stated its much easier to find a chassis ground
look behind the headunit for a solid metal
if you have a multimeter this would be a good place to put it to use
Old May 22, 2009 | 02:01 PM
TroysG's Avatar
I wouldn't use the battery because you'll end up with a ton of engine noise issues down the road.
Hasanbaloch
Feb 29, 2024 08:45 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Thunderaan
Jul 22, 2015 07:40 PM
